Programming 98 Forester keyless remote
Hey Bob,
Here are the procedures:
1)open driver's door
2)turn ignition to ON position
3)Press and hold the emergency override - located underneath the driver's side dash, below and to the right of the fuse access cover (coin tray) - for about 15 seconds. The door locks will cycle three times indicating that it is in program mode.
4)Press the LOCK button on he transmitter. The door locks will cycle once.
If you have the security upgrade, the system will chirp 3 times in step 3 and once in step 4.
5)Repeat step 4 for any additional transmitters.
6)Exit the programming mode by releasing the programming button.
Hope this helps.
