2010 Subaru Impreza Percolator Sounds with Cold startup
def. check the radiator level - safely, when the engine is cool. actually look in the rad - don't trust the overflow bottle.
not sure from how you are describing the sound - could this be a slipping accessory belt?
or, does it really sound like a fluid?
maybe open the hood and have someone else start the car and listen. If it's louder inside the car, could be something with the coolant, a/c or fuel tank. If it's louder under the hood, maybe a slipping belt or.....?
also, next morning before starting, remove the gas cap. note any pressure in there, start the car.
Edited by 1 Lucky Texan
  • Like 1
