ivantruckman Posted September 24, 2015 Share Posted September 24, 2015 I have a 91 ea82 autovagen , that is spfi , just did a tune up / plugs wires cap rotor / on it 5 k miles ago . running great , yesterday it started idling rough. and the acceleration off idle is sluggish . after 1500 rpm is does ok . it hesitates at the low end . it will do 65 mph no problem . im thinking egr , or mabe idle air circuit ? . the check engine light is on now too . Link to comment Share on other sites More sharing options...
DaveT Posted September 24, 2015 Share Posted September 24, 2015 I'd be surprised if it were egr. The only idle air failure I had just killed idle. The codes might be a big help. 1 Link to comment Share on other sites More sharing options...
Crazyeights Posted September 24, 2015 Share Posted September 24, 2015 I would check for fault codes and make sure to fix any first. The coolant temp sensor and connector are known problems on these engines too, so get a look at those. Next I would check for a bad spot in the throttle position sensor just off idle. This won't usually set a code but it can cause a bad stumble. Link to comment Share on other sites More sharing options...
ivantruckman Posted September 25, 2015 Author Share Posted September 25, 2015 im thinking a different problem now.... driving it to work today , I was using the defrost. when I accelerated the ducts went from defrost to vent . I was only at 1/4 on the throttle. and it was instantly . ill have to get the propane out and see if I can find it. im sure its intake gaskets. Link to comment Share on other sites More sharing options...
DaveT Posted September 25, 2015 Share Posted September 25, 2015 There should be a check valve in the vacuum line to the vacuum reservoir that supplies those vent actuators. The check valve could be bad, or there is a leak. That could also explain crummy idle. 3 Link to comment Share on other sites More sharing options...
