kirzick Posted September 25, 2015 Share Posted September 25, 2015 Hey all. I'm still trying to get the poor justy going. It has intermediate no spark and bogs and putters while driving and stalls alot. It shows ecu code 11. So far I have replaced: Spark plugs Plug wires Distributor cap and rotor Pick up coil Ignition coil Fuel filter I don't feel like it's a fuel issue,although I do hAve a carb rebuild kit. Any ideas? Thanks guys Quote Link to comment Share on other sites More sharing options...
TOONGA Posted September 25, 2015 Share Posted September 25, 2015 according to the internet error code 11 is Ignition pulse system/crank angle sensor http://www.troublecodes.net/subaru/ does your justy have a crank angle sensor? Otherwise there is still a fault in the Ignition pulse system TOONGA Quote Link to comment Share on other sites More sharing options...
kirzick Posted September 25, 2015 Author Share Posted September 25, 2015 Thanks toonga. I will look for one when i get home. I thought that could be it, but i assumed since the car is carbed and older it wouldn't have one. But these motors are new to me. Thanks! Quote Link to comment Share on other sites More sharing options...
kirzick Posted September 25, 2015 Author Share Posted September 25, 2015 This site doesn't have a crank sensor listed for the 87 justy. http://www.askatech.com/askatechlive/aatfileshare/references/fasttrack/su005.pdf Ive also looked around online and haven't found anything about a new one for sale. Really sad this little car doesn't work, such a blast to drive. Thanks Quote Link to comment Share on other sites More sharing options...
TOONGA Posted September 28, 2015 Share Posted September 28, 2015 (edited) only other thing I can think of is the crank angle sensor which apparently is in the distributor. Or it could need a carby rebuild. TOONGA Edited September 28, 2015 by TOONGA Quote Link to comment Share on other sites More sharing options...
ferox Posted September 28, 2015 Share Posted September 28, 2015 Check the wires that go to the distributor. Check the whole length between the disty and firewall. They are known for cracked insulation that can lead to intermittent spark issues. 1 Quote Link to comment Share on other sites More sharing options...
