Front brake pad removal 95' Legacy
No Torx for the brakes on those years at least not that I have seen. 12mm 14mm 17mm are the common bolt sizes there though I have had a couple times where it was something else such as 15mm or 16mm but I think they were remanufactured calipers. Subaru does not use threaded pistons, at least not on the common man's Subaru models of that era.
Piston compresses in nicely with a C-clamp.
i usually use a large screwdriver to move the caliper towards the rotor,
toward the outside i think.
then i insert the blade in between the rotor and the pad.
since the pads are being replaced it does not matter if you damage them.
on the 95 fronts, the lower bolt doubles as a slide pin.
the bolt is probably a 12 or a 14.
the lug nuts are 19mm
so 5 lug nuts, and 1 slide pin bolt,
and you swap the pads.
tip,
once the caliper swings up out of the way,
you can slide it off of the upper pin by moving it toward the engine.
it slides right off.
lube the pins before you bolt it back up.
  • Like 1
