mcnea001 Posted October 4, 2015 Share Posted October 4, 2015 All: EJ22 is back in the 1995 Legacy L wagon. Pulled it for clutch / seals / oil seal / etc. Got the engine back in and she started after I followed the procedure for priming oil pump! Tanks fairtax4me. Have lots of other question...but the most immediate. Car is getting hot. Was putting fluid in it...and it ran for about 10 mins....went to take it up the street and it moved to H quickly. Also took the cap off and it was pushing fluid out the cap. This car is new to me. When running before did not overheat (in driveway). Oil looks fine. Please God don't be a head gasket after all this work. Anything I am missing here....does this sound like I need to burp the coolant? And what is best way to do that...saw some other threads. Concerned in Annapolis ;-) Thanks, Tom Link to comment Share on other sites More sharing options...
matt167 Posted October 4, 2015 Share Posted October 4, 2015 pull the vent and burp any air.. With as easy as it is to pull a Subaru engine, I wouldn't pull one and not do head gaskets. Even an EJ22E. You can ignore the timing belt if you want. It's non interference so it will only quit if it breaks Link to comment Share on other sites More sharing options...
mcnea001 Posted October 4, 2015 Author Share Posted October 4, 2015 All: EJ22 is back in the 1995 Legacy L wagon. Pulled it for clutch / seals / oil seal / etc. Got the engine back in and she started after I followed the procedure for priming oil pump! Tanks fairtax4me. Have lots of other question...but the most immediate. Car is getting hot. Was putting fluid in it...and it ran for about 10 mins....went to take it up the street and it moved to H quickly. Also took the cap off and it was pushing fluid out the cap. This car is new to me. When running before did not overheat (in driveway). Oil looks fine. Please God don't be a head gasket after all this work. Anything I am missing here....does this sound like I need to burp the coolant? And what is best way to do that...saw some other threads. Concerned in Annapolis ;-) Thanks, Tom Looks like it was air...went back out to check to see if bubbles in reserve tank. No bubbles. Filled radiator more...filled reserve tank. Ran it around the block about 10 times....let it idle...stayed right on the middle of the gauge. Should I jack it up to bleed it some more...want to make sure it is perfect. I am looking for what to come out of the drain...just straight coolant? Tom Link to comment Share on other sites More sharing options...
montana tom Posted October 4, 2015 Share Posted October 4, 2015 After its cold remove upper radiator hose at the radiator and pour antifreeze directly into the hose, until you fill the entire block. Then quickly reattach upper hose to radiator and fill the rest from the radiator cap. Link to comment Share on other sites More sharing options...
idosubaru Posted October 5, 2015 Share Posted October 5, 2015 once it runs without issues - i generally just drive it and check/ refill the radiator after the first drive or two to complete the process. Link to comment Share on other sites More sharing options...
