Need 2nd set of hands Sat evening in Portland!
Here's the deal, my fiancee Shannon is recovering from surgery so she really isnt in a position to help me wrench in the garage right now.
I want to try to run my 87 GL in the rallycross on Sunday.
But... I need to finish my engine rebuild and that means the clutch and the rear main seal need to be finished still. That means I need someone to hold a screwdriver in the flywheel while I break it loose or someone to turn the breaker bar while I hold the screwdriver.
I will offer beer and or pizza for any help! I know some of you are down early for the rallycross in Hillsboro and I am not far from there... from the fairgrounds go East on Cornell Road to 185th. Go South to Canyon Rd. Turn left, go East to Murray Blvd, turn right, go a block, turn left on Farmington, I'm afew hundred feet East. (Cornell Road MAY go straight to Murray, but I forget...) I know my other directions work for sure.
I should be home around 7-8 PM from work and will be wrenching until the car is done!
My # is (503)526-2997 if anyone out there is willing to lend a hand. :drunk:
Thanks Craig (GLCraigGT)
we got the flywheel and clutch off, did the rear main seal and put on the new clutch and everything.
the engine is now in the car and the only things to finish up as of now are:
1. Fill with fluids
2. Attach fuel line to weber
3. Bolt on exhaust/install gaskets
4. Bolt on engine mounts
5. Plug in alternator
6. Install belts
7. Swap XT seats back in :cool:
