I'm not completely sure on that year but earlier years the tradition was the lines ran from under the rear seat above the fuel tank to each rear wheel, at least on wagons though I think sedans might be the same way. If you life the rear seat on the passenger side you might see like a plastic sticky piece that if you life will reveal where the brake lines go from inside the cabin to under the vehicle.
Yep, both rear wheel ones go through there, they go down, go to a mounting/junction block, then one goes to rt wheel, one to the left.
Probably the other one is ready to go to. My drivers side rear line went out, nothing usable all the way over to the connection at the control arm.
I patched in new up top.
