subaru forever Posted October 14, 2015 Share Posted October 14, 2015 broke off inside and fell inside.any help? Link to comment Share on other sites More sharing options...
desertsubaru Posted October 14, 2015 Share Posted October 14, 2015 A better description of where it broke off at and where is inside? Did it go down into the cylinder or just the tube? What year and engine? Link to comment Share on other sites More sharing options...
subaru forever Posted October 15, 2015 Author Share Posted October 15, 2015 (edited) 2.5 engine.i think in side cylinder .99 outback a-t Edited October 15, 2015 by subaru forever Link to comment Share on other sites More sharing options...
lstevens76 Posted October 15, 2015 Share Posted October 15, 2015 Was it the top or the bottom part of the plug? If it has any metal in it get one of those extendable magnets and pull it out. Otherwise your going to need something like this: http://www.harborfreight.com/24-inch-2-in-1-pickup-tool-94162.html Link to comment Share on other sites More sharing options...
subaru forever Posted October 15, 2015 Author Share Posted October 15, 2015 bottom part of plug.i can not fell any part of the plug. Link to comment Share on other sites More sharing options...
Rooster2 Posted October 15, 2015 Share Posted October 15, 2015 I just changed sparkplugs on my 99 OBW, so I may have some advise. If you broke the porcelain part off the sparkplug, you should be able to reach in with an angle head needle nose pliers. I assume if on the driver's side, you have removerd the car battery for access, or removed on the passenger side, the air intake box and large plastic tubing to gain access. With porcelain part removed, the metal base can be removed with an ordinary sparkplug socket attached to a very short extension, attached to a drive handle. Link to comment Share on other sites More sharing options...
subaru forever Posted October 15, 2015 Author Share Posted October 15, 2015 (edited) could it have fallen deeper into cylinder? the plug was loose broke off .bottom part .passanger side Edited October 15, 2015 by subaru forever Link to comment Share on other sites More sharing options...
jp98 Posted October 15, 2015 Share Posted October 15, 2015 If a part of a spark plug is actually broken off and fallen into the cylinder your only two choices are either trying the magnet or pulling the head. There is no place for the part to go other on top of the piston or along side it, either case it can cause problems. Can you see the spark plug hole into the cylinder or is it still blocked from view like part of the plug is still in the head? Link to comment Share on other sites More sharing options...
Rooster2 Posted October 15, 2015 Share Posted October 15, 2015 On 10/15/2015 at 12:19 AM, jp98 said: If a part of a spark plug is actually broken off and fallen into the cylinder your only two choices are either trying the magnet or pulling the head. There is no place for the part to go other on top of the piston or along side it, either case it can cause problems. Can you see the spark plug hole into the cylinder or is it still blocked from view like part of the plug is still in the head? It is not possible to see "look into" the spark plug hole on a 99 Subie while the engine is still in the car. The engine would have to be removed from the car to do that. Link to comment Share on other sites More sharing options...
DaveT Posted October 15, 2015 Share Posted October 15, 2015 What about using a mirror? I so dislike modern engines.... Link to comment Share on other sites More sharing options...
subaru forever Posted October 15, 2015 Author Share Posted October 15, 2015 can the broken plug be removed.without removing engine.if fell in Link to comment Share on other sites More sharing options...
subaru forever Posted October 15, 2015 Author Share Posted October 15, 2015 got it out.thanks Link to comment Share on other sites More sharing options...
jp98 Posted October 15, 2015 Share Posted October 15, 2015 On 10/15/2015 at 12:39 AM, Rooster2 said: It is not possible to see "look into" the spark plug hole on a 99 Subie while the engine is still in the car. The engine would have to be removed from the car to do that. If I would of thought that something had fallen into the cylinder or something had broken off and fallen into it I would do everything that I could think of to see inside that cylinder including going down to the nearest Harbor Freight and purchasing a fiber bore scope to investigate it further. I hate pulling heads when you don't have to. Link to comment Share on other sites More sharing options...
robm Posted October 15, 2015 Share Posted October 15, 2015 subaru forever, how did you get the bit out? What part fell in? Link to comment Share on other sites More sharing options...
CNY_Dave Posted October 15, 2015 Share Posted October 15, 2015 Not oin a sube, but I have removed similar from a cylinder by shooting compressed air in through a skinny metal line, put it way down in the cyl and move it around... Link to comment Share on other sites More sharing options...
