2000 Outback transmission issues
Ok so here's the deal, Picked up this car (2000 outback limited AWD, Auto trans) from a good friend (122k on it) did HG's and all that happy stuff... friend had transmission and front diff rebuilt by amco (35-40k ago) I'm getting a constant clicking from the drivers side output shaft area, its not a CV clicking but sounds internal, driving patterns don't make any chance to noise, going into neutral while coasting makes it go away and also does clicking when all 4 wheels are on jack stands, I also found that the drivers side wheel appears to be binding when the other 3 are spinning.
Any ideas here? i'm not fond of amco but might take it back....its outta warranty
Edited by jackinthecrack
swap axles side for side to confirm it isn't the SOJ/tripod joint.
inspect brakes for binding caliper.
(woner why the front diff got rebuilt - anyway, there's tricky diff preload procedure I think and it may have had a short lifespan if it wasn't properly rebuilt.)
Edited by 1 Lucky Texan
rebuilt axles are notoriously poor in quality. if they are truly 'new' (as in, new Subaru axles) I would trust it isn't a cv joint. But rebuilts often have the case hardening ground away, cheap over-size bearings dropped in, cheap grease added, etc. maybe 1 out of 10 will last.
just make certain it IS the diff before proceeding to swap the trans or w'ever..
well I was wrong on previous rebuild on differental, was Trans only.
I took it into a shop (amco) they said diff needs gone through, $1530!
so my cheapness has kicked in, what are my options at this point? I'm thinking of finding another trans, what year should I look for?
might do this myself, autos aren't my thing, I've rebuilt a couple suby motors, not afraid here
  • Like 1
Don't use a 99 to 04 Legacy.I think you want the 4.44 not the 4.11. I only know cause I have a legacy and everything else was 4.44 from Impreza to Forester to Baja except Legacy.
One of these might be your transmissions here: http://opposedforces.com/parts/legacy/us_b12/type_21/automatic_transmission/at_transmission_assembly/
If one of them is your transmission then you need any tranny that starts with TZ1A4ZXXXX which as you can see all the 99 to 04 Subaru outbacks, Automatic with 2.5l engines have a TZ1A4ZXXXX number.
I'd take it to another shop and get a second opinion before dropping money on a trans.
Have you checked thefont diff fluid? How does the front diff fluid look? Drive the car a few minutes and drain the diff fluid into a clean bucket or catch pan and look for sparkly bits in the fluid.
I did drain front fluid before this happened, it did have sparkles in it...looked like brass though, and it was about half full, it had a strange smell to it kinda skunky, not the normal gear oil smell, I thought maybe someone put some magic punch in it. I'm thinking it was getting ready to crap the bed.
I snagged a 50k mile tranny off eBay from a localish jdm parts company, comes with a great unlimited mileage warranty for 1yr and I got it for 700 with tax
