Okay I'm starting this engine swap. I'm working on a 03 Outback 2.5 single overhead cam. The engine threw a rod i talk to a few people here on the message boards and they told me I can use any 2.5 dual overhead cam or single overhead cam.
So I picked up a 2.5 dual overhead cam engine I am going to pull the heads and intake off the engine that I'm taking out of the car and I'm going to put them on the new block I just got. but as I am pulling out the engine right now I discovered there's more bell housing bolts then just 4 is that going to matter when putting the new block back in the car¿¿??
No the four bolts is all it needs and they line up just fine
Yes I actually figured that out when I got the engine out I took my extra adapter plate for the ej to ea and it fit perfectly kind of freaked out for a second before I pulled the engine thinking oh no I got an engine that won't work but thank you anyway
