Zem Posted October 31, 2015 Share Posted October 31, 2015 About a year ago I decided to repair the holes in the dashboard. This meant taking the whole thing out. I thought it would be a few days, but it turned into over a year (though the dash has now been flocked green). The problem is I was not great with documenting it, and it has been to long to remember where everything went. Most things went back together alright, but there are two issues... and I hope very much that they are related. 1) The HVAC fan doesn't work. I have tested the fan itself, and it is fine, so I am not getting power to it. I have checked the fuse, but it seems the switch doesn't see any love. 2) I have a bracket with a relay attached to it, and I have no idea where it goes. Hopefully it is related to the HVAC fan. I *believe* it goes under the steering wheel based on the prong things that hold up the round relays. It's worth noting that KingBobDole did a swap on this, so I'm not even sure anything connects to this relay. The relay has room for 6 connectors, but there are only 4 of them. There is a dangling connector that only has 2x2, so it would fit, but... that would be weird, right? If it's 2x3, even if it only has 4 actual wires, you'd expect the connector to have 2x3 and two empty slots. So anyway, if this looks familiar to anyone and you can give me some idea of where it goes and what might plug into it, I'd greatly appreciate it. Link to comment Share on other sites More sharing options...
jono Posted October 31, 2015 Share Posted October 31, 2015 the fuse box sort of hangs off that triangular section, usually with a white plastic insulator, headlight round relays and their own bracket screw to the other holes ...try that and see how puzzle fits back Link to comment Share on other sites More sharing options...
Zem Posted November 1, 2015 Author Share Posted November 1, 2015 Thanks, that helps me figure out how the fuse box attaches. The only plug that is 3x2 in the area is what plugs into the lights. The 2x2 is near there... Link to comment Share on other sites More sharing options...
Zem Posted November 2, 2015 Author Share Posted November 2, 2015 It is indeed a 2x2 connector that plugs into the 3x2 relay. I figured the car might burst into flame, but I tried it anyway. It works! Link to comment Share on other sites More sharing options...
