jread Posted November 2, 2015 Share Posted November 2, 2015 Found a pretty good price on a winch up here but it says for ATV/UTV but has a 4000lbs rating. http://www.canadiantire.ca/en/pdp/4-000-lb-atv-utv-winch-0405953p.html#.Vja1lLerRmN Do you guys think this would pull a loyale? I've read 1.5-2x vehicle weight and by that it works out but just skeptical because its ATV specific. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted November 2, 2015 Share Posted November 2, 2015 I'm running a similar one, mines rated at 4500. Get a pulley so you can double the pulling power , mine has done everything I needed it to do, your not going to pull out a stuck pickup with it but it will pull your rig, remember the more cable you have pulled out the more powerful your winch will be 1 Link to comment Share on other sites More sharing options...
ferp420 Posted November 2, 2015 Share Posted November 2, 2015 my 3k in sigle line pull wouldent pull my loyale out by it self when i wedged it in to some rocks i had to use the high lift to un wedge it then it pulled it off the rock i was high centered on the only down side is the cheap atv winches have a shorter duty cycle no big deal unless your winching up alot of long hills a 4k might have been enuff to move the rock too doubld up it should do anything your little car will ask of it or pull the car apart while trying but i wouldent reliey totaly on the winch a good jack and a strap or chain and a shovel work wounders Link to comment Share on other sites More sharing options...
