Another Brat, but this one is mine!
iluvdrt
Now that I finally upgraded my OS on my computer I can post pics, so I am going to start a journal of my Brat.
So, I have been into "Old School for awhile and have always wanted a Brat. They are just hard to come by where I used to live in the North East. after almost 16 years of searching for a good one (I hate rust), my buddy found one for sale on NAS**C and he hit me up. It was located about 40 miles North East of Sacramento....430 miles from me. I figured I only had a couple more years here in SoCal so Friday after work a friend and I made the trip to get it over the weekend. What a trip it was. Long story short I bought it after a 5 mile test drive and drove it that day all 430 miles back home at a comfortable 60 mph (LOL). The seller was a great guy and owns a small Subaru shop. He was nice enough upon hearing of my plan to give it a good run through and even replaced a few parts on it for me to ensure it would make the trip. I became the 3rd owner of this 82 Brat DL. This is the day I got it home.
933913_10203935018234305_851155401886581
1016305_10203935978218304_42104376088784
1379945_10203935978978323_55524636728678
10441106_10203935979258330_9010924531199
Now that I had it home I had to start right away fixing her up. I pulled all of the badges off and repainted them by hand. Along with the grill and side louvers. I also used a Mothers 3 step buffing wax to try and restore some luster into her paint.
Here she was after that
10649532_10203976428669540_5885017339164
10437725_10203982297776264_5323823601078
10686783_10203982299736313_3664107450086
I also cleaned the interior (which took a gallon on simple green) and installed my old Hurst shift knob. Its been in every car I have owned the past 20 years. I did have to get some adapters for it though since the last car it was in was a Toyota Truck.
10525606_10204057045404908_1576689870383
Now that she was somewhat clean, it was time to focus on the other things. The brakes were horrible. I changed all of the lines, the pads, rotors, shoes, and gave her some Lucas synthetic DOT 5 brake fluid. I also turned to getting the car running better. The crappy 1 brl carb and all of the emissions stuff was really robbing her of power so I sourced an old weber from a member on here and rebuilt it. After some extensive searching for weber parts, and me trying to remember how to tune a carb engine I finally got her running good enough.
I also replaced both rear shocks, the springs, struts, strut mounts with all new Sachs parts, and replaced both front CV axles with EMPI ones as well as all of the bearings and seals. I kept the original axles to rebuild later. I also changed the distributor to a new A1 Cardone one, all the plugs, wires, cap and rotor, coil, and fuel filters.
10336704_10204111887255920_7608467114439
10849865_10204220545212301_2936305327789
The rebuilt Weber 32/36
10474191_10204525264870102_3722349632114
10980763_10204674473840233_4222584345612
Later I realized the 4 speed can't handle the speeds of California traffic, so I opted for the 5 speed conversion. I just happened to find one at my local junk yard still in a GL wagon for $150, so I pulled everything I needed, contacted Jerry for a Jerry's kit, and went at it. During that time I noticed the water pump was leaking, so I ordered a new water pump. I figured why stop there, so I also decided to pull the motor and reseal/ clean it. I also went ahead and ordered a Redline Fuel pump, Summit fuel gauge, Holley fuel pressure regulator, and decided to degrease/ wire tuck the engine bay.
11045500_10205294729506237_6298608155347
11223858_10205294729706242_6849016582140
I always chase holes with a tap, and the bolts with a Die.
11072190_10205294731146278_5023107540346
11205516_10205294731906297_8539448903226
11014940_10205294732186304_2497429712865
Cleaned and painted
11391102_10205489786022528_7399022242660
Ready for install
11427767_10205502563661961_9045208821210
The filthy engine bay
10353042_10205540701815391_5371386112074
Clean engine bay. After it dried, I touched up all of the paint.
11229893_10205540702575410_2893486585845
5 speed install!!!
10996767_10205569917425763_7280904566477
11031083_10205569917745771_8135809530680
11536125_10205569918625793_2735886346574
Installing the shifters Jerry made. His workmanship and help with this were top notch! He helped me a lot over the phone.
10533891_10205569920025828_8946027634455
New custom driveshaft. It uses 1 ton Spicer 1460 U-joints and is rated to 600 HP LMAO!
11535663_10205643690430042_1807170612834
I also ordered a Magnaflow header too
1907497_10205643690710049_50333638682862
  • Like 1
Wonderful work so far! I though the car show pic was pretty funny. There is a cars and coffee that I go to and there is everything from turn of the (last) century cars, lots of pre war stuff, all the way up to the latest exotics. I took my 82 Brat before tearing it down for the paint and such and it was a huge hit! Lot of "I haven't seen one of these in years!" and "Can I sit in the back?"
  • Like 1
Engine is back in and everything is ready to go!
10660255_10205595707630502_7749725652268
10561676_10205643690070033_7972756298002
Since I had the interior out, I figured I would update it a bit too. Plastidipped some stuff and installed a JVC MP3 player, kenwood speakers, and some lights inside....just like the 80's!!
10408916_10205694450219005_8624221678379
12190815_10206450359036253_2325257140692
I decided to rhino line the back too
11178334_10205261052664337_2187403831824
And do the control arm bushing since it squeaked.
12074621_10206351679569328_5345020279515
12144939_10206354409277569_6691300923217
Subiefest was coming up, so I decided to enter the Brat into the car show with my Brat SCX-10 RC Crawler I made too
11206950_10206246343816000_5875687180170
Close up of the RC in case youre curious
12187899_10206466349996017_6366936375256
12196294_10206466349756011_1862716948316
Anyways, back to Subiefest. Lots of tough competitors there
12003179_10206251604387511_1684308697943
My beautiful wife of 24 years (total time together) supporting my crazy habbit lol
11221899_10206161891304740_8797126411656
And.......I WON!!!
12038286_10206251593707244_2077550864180
Good cruise home
12144867_10206458378676739_5146489606650
That's it so far. I bought a ADF 4" lift for it so Ill be doing that soon, but funds are a little tight since I also bought this a couple months ago
And I still have this for wheeling
11703186_10205762193672549_6516620399911
Edited by iluvdrt
  • Like 3
  On 11/3/2015 at 1:33 AM, subarubrat said:
Beautiful engine too! Where did you find the Magnaflow?
Thank you. I got it from Summit. It cost me a fortune because it isn't Cali legal so I had to ship it from Cali to my dads house when I bought it, and then he shipped it to me since Summit wouldn't ship it here.
It sounds beautiful, and Im trying to load a sound clip. It is stainless steel and JET coated.
  On 11/3/2015 at 1:48 PM, Loyale 2.7 Turbo said:
That is a very nice Brat, and you've done an Awesome Job with it. Congratulations!
So, you want to Lift it 4" + add bigger Tires, isn't it?
Keep us updated, Kind Regards.
  On 11/3/2015 at 3:04 PM, bratman18 said:
Love your attention to detail. Great work so far. I've been a supporter of you installing the lift since you got it lol. Glad you've decided to. Doesn't mean you need to wheel it! I look forward to seeing progress!
Yeah I decided to lift it. It probably will never go off road, or at least anything serious. I also plan to add power steering as well. Ill do the 6 lug conversion and runs some 14's with probably a 215/ 70/ 14 AT tire. I don't want anything too big that will hurt the power of the engine as right now it runs great.
  • 2 months later...
Well, I finally decided to lift the Brat. I used a ADF 4" lift which seems to bolt in almost flawlessly. Originally I installed the strut mounts backwards but that has since been sorted. I still have lots to do which includes extending the brake lines, fixing the shifters, getting EA82 hubs for the 6 lug conversion, longer shocks for the rear and extending the bump stops, extending the steering, fixing my brush guard mounts and adding a skid plate, getting 15" rims and 27" super swampers, and fixing the lower radiator hose. I'm also going to get a custom exhaust made that tucks up under neath.
I am super happy with the outcome so far!
  • Like 1
  • 1 month later...
Well time for an update.
I ended up just drilling the EA81 hubs and welding in new studs. The wheels I ordered are Method Race wheels in a 15". I also ended up going with 215/75/15 BFG AT KO 2's. Slightly larger than the swampers I was wanting, but the swampers weren't available. The 215's measure in at 28.6". I did have to trim some of the fender and do some hammer work on the inside of the fender well where the body seam was. I still have some slight rubbing inside th fender well, but not enough to be concerned about. The rear was perfect.
I ordered the Rancho 5241 Shocks and they are the perfect length. It rides beautifully. I also got my brushgaurd refitted with an aluminum skid plate made. My exhaust was all custom from the header back. It is 2.5" OD and has a stainless steel turbo muffler. Its a little quieter than I would have liked, but I am also enjoying how quiet it is the more I drive it.
My MPG's dropped from 28 to 25 overall and my speedo is off about 18%. I can still do 75-80 on the highway and even go up hills without downshifting, but I really feel the old engine is being overworked so I am looking into regearing the trans and diff with 4.11's or 4.44's from Subieworks.
Anyways, here are a couple pics, if you follow me on FB or Instagram, you've probably already seen it. Method Racing even posted it on their Instagram site which received over 3,000 likes lol.
The RC car in the second pic is a custom Axial SCX-10 rock crawler I built.
  • Like 1
  On 3/9/2016 at 9:44 PM, iluvdrt said:
Well time for an update...
Your Brat really looks Awesome!
The wheels looks pretty good; Maybe you might feel better engine response downshifting and keepin' the engine a little Higher on the RPM's than what you used to drive; in my case, I only went to 25" tires to keep the Balance between Daily Driver and Offroader, plus the MPG closer to stock; but still I use the Subie pretty High on RPM's, downshifting more often, and seems like these good ol' EA engines likes that.
Kind Regards.
  • Like 1
Kind Regards.
Thanks.
Yeah it definitely has to be down shifted more, but that is OK. Originally I wanted a smaller tire like a 26, but this size was the only size that was available to me at the time. I didn't want to get into having to trim the fenders or anything, but unfortunately I had too.
I'm still getting around 25 MPG at 65-70 mph, so I guess that's not too bad.
  • Like 1
awesome build so far! i just picked up an 86 gl hatch and want to do a 5speed and 4" lift as well. i talked to jerry about his conversion kit today and he said its totally different setup for a lifted rig. did you have to rework the mods he did for your 5 speed conversion originally?
cheers!
No, his kit is still un use. I used a small spacer for the 4WD shaft on the transmission so that shifter would sit normal and a 2" drop down bracket to mount the 5 speed shifter too instead of mounting it to the body. It did lower the shifter a bit into the body, but with a few careful bends everything worked perfect.
