johnvaudo Posted November 6, 2015 Share Posted November 6, 2015 having an issue and I need some help. My 98 legacy cut off the other day. I checked the fuel pump it is ok, I checked the ignition coil it is ok but not appearing to get spark when I pull the #1 plug and ground the tip. I replaced the Ign Coil and got the same results. not sure where to look from here. it turns and turns but does not catch and run. HELP PLEASE!!!!! Link to comment Share on other sites More sharing options...
Olnick Posted November 6, 2015 Share Posted November 6, 2015 Welcome to USMB, johnvaudo. Please post your problem in the New Generation forum--I'm sure you'll get some help there. Link to comment Share on other sites More sharing options...
subarutech1873 Posted January 26, 2017 Share Posted January 26, 2017 I am having thr same problem cyl 1 and 2 have no fire/spark Link to comment Share on other sites More sharing options...
