Fairtax4me Posted November 10, 2015 Share Posted November 10, 2015 Friends 99 Forester needs an AUTO trans. She's had the DFE problem since she bought it. Couple years ago I put trans X in it and that took care of it for about a year then an ex of hers decided he would work on it and did something that caused a leak. I fixed the leak, transX again and she was good to go for another year or so. But now trans X isn't cutting it anymore, and it's been slipping on occasion. To avoid getting one with the DFE problem, I think I should be looking for an 01-03 from a Forester or Legacy Outback... right? It's been a while since I've looked into this stuff, so just want to make sure before I start checkig around for prices. Link to comment Share on other sites More sharing options...
idosubaru Posted November 10, 2015 Share Posted November 10, 2015 That's my guess 01-03, 01's are suspect for that issue too though. I haven't commited Phase II autos to memory, Phase II, 1 sensor verses 2 speed sensors, Duty C changes in 2003...forester/legacy differences...gets confusing in my eyes. I usually just google it and try to find one person that's done the exact years i'm looking at....but obviously you're trying to start with what you can search for. I think you can use even later trans...03-04 with the reversed Duty C if you address the signal reversal - CNYDave knows that issue... Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 10, 2015 Author Share Posted November 10, 2015 I remember reading about Daves 03-04 C duty solenoid debacle. Id like to avoid having to make modifications to make this work. I wasn't aware that the 01+ transmissions had the DFE as well. Thought that was just a 99-00 thing. If that's the case I may convince her to just let me rebuild it. Link to comment Share on other sites More sharing options...
CNY_Dave Posted November 10, 2015 Share Posted November 10, 2015 Just watch the gear ratios, auto legacy's have 4.11, outbacks 4.44's, 04 donor trans needs a few swapped parts in the tail section. Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 11, 2015 Author Share Posted November 11, 2015 Forester should be 4.44 right? Car-part.com lists 99-01 as interchanable. Safe enough to think 01-03 should be fine. Link to comment Share on other sites More sharing options...
