Sezb10 Posted November 11, 2015 Share Posted November 11, 2015 Hi Guys, I have a 1995 Subaru Liberty Heritage, 2.2l Auto, 190k on the clock. About 3 months ago I had a major 6year service on it - about a week later the engine light came on, took it back to the mechanic and they changed an ignition coil and the alternator. Recently I have been having an issue when I drive on the highway - the temp gauge appears to fluctuate - it will go up near max but just as quickly comes back down to normal temp again. A couple of days ago I came off the highway and was idling at a red light - the revs jumped from the normal 500 to over 1k for a couple of seconds. The temp gauge was showing at almost max (car did not appear to be overheating though and no issue with the coolant level). This has happened on a couple of occasions - always seems to be after I have driven on the highway (which I only do approx. once a month). Also a few days ago sitting at a red light the revs jumped up for a few seconds and engine light came on for about 30 seconds (engine light not on at the moment). Any ideas of what could be going on?? Would really appreciate it! :-) Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 11, 2015 Share Posted November 11, 2015 (edited) rebuilt alternator could be bad - that system needs to be checked, overcharging a battery is not good. Could also be a bad/intermittent ground wire somewhere. They can need to be 'refreshed' on older cars. is the check engine light on? might check for pending codes anyway (is it OBD I ?, will the old system store pending codes?) Edited November 11, 2015 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
Sezb10 Posted November 13, 2015 Author Share Posted November 13, 2015 Thanks for your response. Check engine light only came on for about 30seconds when idling and revs jumped up for a couple of seconds - light is no longer on. I'm presume it's OBD I but not 100% sure. I'm leaning towards Coolant Sensor at this stage..have had a couple of instances on really cold mornings when I haven't let the engine warm up - the car has struggled at low idle (at stop signs/red lights) where the car has effectively stalled/lost all power (I'm guessing probably flooded engine). I took it into the mechanics to do a diagnostic scan and they reckon no codes came up. Possible dodgy mechanic as I had a mate plug in 2 different scanner tools and they couldn't get any power through the dash to the scanner?! Not too good with the electrics/computer side of things unfortunately. But done all the mechanical checks and can't identify any issues elsewhere that would cause it. Link to comment Share on other sites More sharing options...
