lmdew Posted November 11, 2015 Share Posted November 11, 2015 I have a 2005 OBS and the PO had dogs. I need to replace the window seals, and on these cars the seal is one large piece that also runs down the B-Pillar. The B-Pillar has a plastic trim piece held on by 4 plastic clips. How do you remove the trip without breaking the trim or clips? I've tried a couple at the yards and the top to clips have a inverted U clip and the bottom a normal U clip slots. Thus you can't slide it up or down to remove the trim. I know there is a trick, what is it? If no knows for sure, I'll head to a body shop and ask them to remove it. Thanks, Larry Link to comment Share on other sites More sharing options...
