I have a 1990 subaru legacy manual Trans and I've been having quite the idling issue. I just replaced the MAFS and she still won't idle what so ever. I'm planning on cleaning my throttle body and replacing the gasket to see if that helps. I've already replaced the top end throttle body vacuum line and it didn't do anything to help. I need some wisdom due to this being my first import please help me out
90-91 had problems with the idle air control valve. Need to try cleaning that first. If it doesn't help the valve may need to be replaced.
There is a large hose that runs from the idle valve to the intake tube. Make sure it's connected. Easy to overlook if you move the intake tube to change the filter.
  • Like 1
