Coolant Crossover Pipe ORings
I had to service that pipe on my '92 this year and I replaced those O-rings while I was at it.  I am pretty sure they were round in cross section (like an O-Ring should be!) but to be brutally honest, my memory is shot and I don't clearly remember!  But the bottom line is, they are not expensive and my opinion is that this is one of those cases where you really should replace them "as long as you are in there".  You will kick yourself if they leak after you reassemble all that stuff.
