philr Posted November 16, 2015 Share Posted November 16, 2015 Hi Subi folk, I have an issue or two with my old DL wagon. And hope someone can help me sort it out. She is currently unregistered, and probably unroadworthy. Firstly my old 1990 DL wagon is overheating. It has an electric fan linked to a temperature switch in the radiator The fan works fine when connected directly to the battery. The temperature switch seems fine. -I thought it might be faulty so swapped it over with a spare. still no joy so then tested the original one in a kettle of boiling water and it tested fine for continuity at temp. So I figured that wasn't the problem. I tested continuity of wires from the fan to the fuse box - checked out ok. And there is 12+ volts at the fuse box The fuse is not blown. I'm not sure how to check the other bits of the wiring - I have a manual for an 1986 model, which shows the fan and radio sharing a fuse but not the 1990 model which has a separate fuse for the fan I am new to auto electrics, and did some youtube tutorials on how to use a multi meter - but I'm not super sure I have done it correctly. Any suggestions would be warmly welcomed. Thanks Phil Link to comment Share on other sites More sharing options...
Rust Posted November 16, 2015 Share Posted November 16, 2015 I would just run a toggle switch so you can manually control the fan. Link to comment Share on other sites More sharing options...
ferp420 Posted November 16, 2015 Share Posted November 16, 2015 or just wire it to the ignition so its on when the ignition is on then you never have to think about it again you here it when u turn the key on so u know its working Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 16, 2015 Share Posted November 16, 2015 But if you want it to come on / off as it Should, and elongate the fan's lifespan, you can check the wiring for the Thermoswitch, searching for corrosion, because it takes the Ground signal from a place around the frame rail... maybe it only needs a good cleanup of the contact bolt, or put the ground to another, cleaner bolt. Kind Regards. Link to comment Share on other sites More sharing options...
NocturneVoyager Posted November 16, 2015 Share Posted November 16, 2015 I don't know if this has already been checked or not, but I had a problem with my 86 XT GL overheating and could not figure it out. Finally took it to the shop and they told me that the radiator was congested/constricted about 90%, so had to be swapped out - could not be flushed out. Not sure if you already checked down that road or not. Link to comment Share on other sites More sharing options...
