bgambino Posted November 24, 2015 Share Posted November 24, 2015 2006 forester non turbo 104,000 Bought it from an older friend who took really good care of it Been driving fine for 2 months All of a sudden it shifted hard into OD when cold yesterday (about 30F here in NY) Stopped...started again and did it once more. a mile later stopped in grocery store...seemed fine after that This morning did the same thing The fluid is at normal level and extremely clean I don't know what's in there but it is not the typical red color I am used to It's almost clear...I have to look again and take a picture I really don't need a tranny issue...! Especially when we all know I will have HG issues at some point too... Anyone have some insight please? Link to comment Share on other sites More sharing options...
AdventureSubaru Posted November 25, 2015 Share Posted November 25, 2015 Start with the basics. I'd do the 3 time drain/fill method to make sure you have the correct and fresh fluid in there. See if the problem persists. Some additives/cocktails out there are good for cleaning / smoothing things out if fluid alone doesn't cure it. 104 is still early for these transmissions. 1 Link to comment Share on other sites More sharing options...
Rooster2 Posted November 25, 2015 Share Posted November 25, 2015 Start with the basics. I'd do the 3 time drain/fill method to make sure you have the correct and fresh fluid in there. See if the problem persists. Some additives/cocktails out there are good for cleaning / smoothing things out if fluid alone doesn't cure it. 104 is still early for these transmissions. +1 on above advise. There may be an external spin on filter for the auto tranny. If so, changing the filter would be a good thing to do at ATF change. Please don't drop the tranny pan looking for a filter in there. It would be only a screen wire that never needs attention. Dropping the is a big mistake, as the pan never seems to bolt up again without leaking. Been there, done that!!!! Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 25, 2015 Share Posted November 25, 2015 ... The fluid is at normal level and extremely clean ... not the typical red color I am used to It's almost clear... To me, sounds like it might contain certain additive(s) mixed, such like TransX. Worth check the coolant state, maybe the ATF and Coolant are getting Mixed. However, a Drain and refill with fresh ATF of good quality, such like Valvoline's "Maxlife" might help to solve it. Kind Regards. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 25, 2015 Share Posted November 25, 2015 (edited) if it is the ATF-HP stuff from Subaru, it could be red in color if still made by Idemitsu. (some say 2 different sources have made it so.....?) But, a fluid change is a good , DIY place to start. inexpensive compared to almost any other trans work. However, another concern might be whether someone has confused the front DIFF for the trans fill tube. It has happened before. Edited November 26, 2015 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 25, 2015 Share Posted November 25, 2015 A lot of newer ATF mixes are clear. Some are blue. Even saw some that was green once. Fluid color doesn't really determine what it is, just depends on what color of dye the fluid manufacturer feels like putting in it. If the fluid is burned that's a problem. Doesn't sound like yours is burned, but old fluid can sometimes cause issues. A drain and refill + new filter isn't a bad idea, especially if the fluid has never been changed. Link to comment Share on other sites More sharing options...
bgambino Posted December 7, 2015 Author Share Posted December 7, 2015 So far it seems to happen when the mornings are at or below freezing After 3 miles of so...seems to stop doing it I am going to let it idle for 5 minutes and warm up a bit on the next morning and see what happens Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 7, 2015 Share Posted December 7, 2015 So far it seems to happen when the mornings are at or below freezing After 3 miles of so...seems to stop doing it... Well, my Wife's car which has the Automatic F4-EAT, does exactly the same if she or I drive the car immediately, after starting it cold in the Morning; but Never does that if the car has reached its normal operating temperatures. Kind Regards. Link to comment Share on other sites More sharing options...
