ducunee Posted November 26, 2015 Share Posted November 26, 2015 85 BRAT. Starting out by backing up there is a grinding noise that sounds like worn brake shoes against the drum, checking those they are good. the cv joints are original (103K miles) and no visable sign of grease leakage. No driving problems not in 4WD although there is constant noise from the rear. Also any way to reduce the sound coming from the fuel pump mounted to the frame? Link to comment Share on other sites More sharing options...
l75eya Posted November 26, 2015 Share Posted November 26, 2015 Aside from the actual shoes in the drums, I would inspect all the springs to make sure none are broken / hanging off. 1 Link to comment Share on other sites More sharing options...
jonas Posted November 26, 2015 Share Posted November 26, 2015 +1 for the broken spring. Link to comment Share on other sites More sharing options...
ducunee Posted November 27, 2015 Author Share Posted November 27, 2015 Could a bad bearing cause the noise? Link to comment Share on other sites More sharing options...
Dee2 Posted November 28, 2015 Share Posted November 28, 2015 If it was bearings you should hear it all the time, not just backing up. Link to comment Share on other sites More sharing options...
TomRhere Posted November 28, 2015 Share Posted November 28, 2015 Check engine and trans mounts. The torque load on them differs between forward and reverse. The exhaust is supported by a bracket on the trans, so if trans mount is bad, it cold let exhaust rub on something while reversing that it wouldn't rub on going forward. Just my .02. Link to comment Share on other sites More sharing options...
