BoostedBoxer421 Posted November 26, 2015 Share Posted November 26, 2015 hey everyone, just a quick question, does the oil in/out of these turbos need pressure to flow (does the turbo pump the oil? or does the engines oil pump supply the flow) same with coolant, i figure the coolant system is always under a certain amount of flow since the pump is always spinning, but does the turbo circulate water or does only the engine circulate it through the turbo? thanks in advance!! Link to comment Share on other sites More sharing options...
naru Posted November 26, 2015 Share Posted November 26, 2015 Engine does the pumping for both. Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted November 28, 2015 Author Share Posted November 28, 2015 i just talked to my mechanic friend and he was telling me that a divorced oil supply setup for turbos dont usually require an external pump. ill have to get back to him on it and we can go do some testing (: Link to comment Share on other sites More sharing options...
