lionsanddawgs Posted November 27, 2015 Share Posted November 27, 2015 1999 Legacy Wagon steering is jerky when turning, even at complete stop. First noticed at low parking lot speeds and tight turns, but now starting to notice occasionally at higher speeds. Power steering fluid level OK. Hoping it's not my steering gear. How would I know if that's the problem? Has anyone else run across this? Appreciate any help. Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 28, 2015 Share Posted November 28, 2015 My first guess would be a loose belt, but if it has the same issue at speed there could be something going on with the pump. Is the fluid dirty or old? Has it been changed since you've owned the car? Make sure the belt is tight and in good shape. 1 Link to comment Share on other sites More sharing options...
lionsanddawgs Posted November 28, 2015 Author Share Posted November 28, 2015 the belt is good. I'll try changing the fluid. Any other ideas out there? Link to comment Share on other sites More sharing options...
nipper Posted November 28, 2015 Share Posted November 28, 2015 the belt is good. I'll try changing the fluid. Any other ideas out there? Not that your going to like. Last ditch try is the universal joint in the steering shaft. Spray it with white lube and see if it helps, otherwise you know the answer. 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 28, 2015 Share Posted November 28, 2015 look for bubbles in the fluid while idling, have someone turn the wheel. you don't want bubbles. 1 Link to comment Share on other sites More sharing options...
lionsanddawgs Posted November 28, 2015 Author Share Posted November 28, 2015 No bubbles. I've changed the fluid. Spraying the U-joint is a good idea I'll try. Thanks for the input, all! Link to comment Share on other sites More sharing options...
