White smoke after starting
When I start my car, I get some white smoke for about the first 5 minutes it runs. I notice moisture from the tail pipe when it smokes. I knew the answer to this one once before. Gasket problem? No overheating. Oil pressure sits under 45 when warmed up.
  • 4 weeks later...
You didn't say is it auto. or manual transmission? The auto. 3sp trans. had a vacuum modulator valve that would leak ATF into the vacuum hose. The ATF would run into intake manifold and burn the fluid out the tailpipe. So re-check ATF & front differential fluid levels.Hope this helps Ralph
When it "smokes" place your hand in the cloud near the tailpipe. You can tell a lot about the condition of a engine by the smell of the exhaust.
Slight fuel, oil smell, white smoke that wets your hand is perfectly normal
Strong fuel smell, running rich
Sweet maple syrup type smell, antifreeze. On an ea that would more likeley be an intake gasket. Not a hard fix
Burnt oil, valve guides, keep tabs on oil use, if its excessve, like more than 2qts per change, you may look at doing these
Burnt oil, that doesnt smell like motor oil, trans fluid. Check the vacuum modulator, only on 3at
