Wheels and Tires question
Ok so I recently picked you some 15x8 wheels and already have them drilled now i am trying to find a tire that is under 29 inches because that all the clearance my struts will allow. So I am looking at son general grabber at2. size is 225/70 R15. Was just wondering if that would fit my rims? any help would be greatly appreciated!
Thanks, Ash
my 235/75/15 goodyear wranglers are around 29.5 235/70/15 on my car right now are about 29" ive run 225/75/15 on a 8" wide rim with no issues only problem you might have is when aired down it would be slightly easyer to pop a bead and or ding the rim
i do rub just a little in reverse under full lock it hits the unibody in front of the wheels just slightly there is enuff room to get my hand in between the tire and spring purch i did use the BFH in a few spots but mostly just to smooth the inside of the wheel well i also cut the isht out of my fendes i ran these tires when i had my 2" lift on also adding another 3" of lift dident seem to change a thing as far as the rubbing goes still hits the same place
