Hello. I'm new here making my first post :)
I just bought a 1995 Legacy to replace my 2000 Outback that's having head gasket issues for the third time in three years. Anyway, the new one has some issues that I was curious about. First, it needs a new alternator. Can I use the one that's in the Outback or will I need to buy one? Second, the Legacy is having minor overheating issues. As in it starts heating up when I go up hills, but the needle never tops out and it will cool down once I'm over the hill. Please please tell me this is an easy fix. I'll scream if I end up with another head gasket issue.
Not sure about the alternator, you can cross reference the part numbers and see if they match.
A couple of things you can check on the heating issues:
Replace the old radiator cap with a new Stant cap.
Replace the thermostat with a ginuine Subaru one NOT aftermarket.
If you even think the antifreeze is old or diluted, drain it and put fresh in when you change out the thermostat.
