subarubrat Posted November 29, 2015 Share Posted November 29, 2015 Just finished re-assembling the 82 Brat other than the interior and trim belt so it was time for first start. The engine does not start and I verified that the pump is not getting 12v. I checked the schematics and it refers to a fuel pump control unit which I need to check the connections to, but no information on what it looks like or where it is, can someone fill me in please on where it is and what exactly it does. Link to comment Share on other sites More sharing options...
Skylar Posted November 29, 2015 Share Posted November 29, 2015 If you're referring to the fuel pump relay it's located on the drivers side kick panel bolted to the bracket for the hood release Link to comment Share on other sites More sharing options...
naru Posted November 29, 2015 Share Posted November 29, 2015 It is a little fancier than a plain old relay. It needs to see ignition pulses from coil -. Make sure all the coil wires are connected. Link to comment Share on other sites More sharing options...
subarubrat Posted November 29, 2015 Author Share Posted November 29, 2015 Coil wires are all there. From searching I saw that there is also a relay under the passenger seat I found two, a round one that clicks when the key is turned to the on position and a square one that does not. No blue box (and nothing was removed from the interior wiring) but there was this box: Link to comment Share on other sites More sharing options...
naru Posted November 29, 2015 Share Posted November 29, 2015 That looks like it. Link to comment Share on other sites More sharing options...
subarubrat Posted November 29, 2015 Author Share Posted November 29, 2015 Which relay under the passenger seat is the fuel pump relay? If it is the round one Im good there, if it is the square one then I might have an issue with that. I hope the factory manual has some info on this unit. Link to comment Share on other sites More sharing options...
subarubrat Posted November 30, 2015 Author Share Posted November 30, 2015 I also can feel a relay in that control box kicking on and off with the ignition being turned to start. Link to comment Share on other sites More sharing options...
naru Posted November 30, 2015 Share Posted November 30, 2015 On 11/29/2015 at 11:23 PM, subarubrat said: Which relay under the passenger seat is the fuel pump relay? If it is the round one Im good there, if it is the square one then I might have an issue with that. I hope the factory manual has some info on this unit. The one in your picture. Link to comment Share on other sites More sharing options...
subarubrat Posted November 30, 2015 Author Share Posted November 30, 2015 The shop manual has more info on the door chime than this fuel pump control unit, any idea which pin is the output to the fuel pump so I can see if the thing is even working? Link to comment Share on other sites More sharing options...
naru Posted November 30, 2015 Share Posted November 30, 2015 I think it is the blue/red. Link to comment Share on other sites More sharing options...
subarubrat Posted November 30, 2015 Author Share Posted November 30, 2015 (edited) Naru thank you very much, your input solved the problem. The module was working as it should, so it had to be a harness problem. I pulled the plastic buttons on the rear plastic panel and found that the previous owner had cut the lines to the fuel pump and ran those lines to a switch hidden under the seat!!!! It got bumped to off at some point. He also had a very early security system on it, the ones with the key on the fender, so he must have been worried about it being stolen. With that crap removed the pump is now shooting fuel to the carb as intended! And she starts and man is that a mean sounding EA81 with all the mods in it!! Edited November 30, 2015 by subarubrat 1 Link to comment Share on other sites More sharing options...
beamsbox Posted January 28, 2016 Share Posted January 28, 2016 When you say the plastic buttons on the rear plastic panel, where exactly are you referring to? Link to comment Share on other sites More sharing options...
