Turbone Posted December 2, 2015 Share Posted December 2, 2015 Co worker is driving a 92 Leggy thats seen better days, belongs to her brother. I try and help her out when I can, replacing the rear struts with some from the wrecking yard. Now her heater quit working, right when temps were in the 20's. All fuses/relays check out, no power to the blower. I suspect the switch is bad. Link to comment Share on other sites More sharing options...
mikaleda Posted December 2, 2015 Share Posted December 2, 2015 Resistor pack failure? I've ran power straight to the fan for a temporary fix before. Link to comment Share on other sites More sharing options...
Crazyeights Posted December 2, 2015 Share Posted December 2, 2015 Sorry to hear this. Heaters seem to fail when it's really cold, wipers fail in the rain, and power windows always seem to stick down in the rain Might want to check the resistor block too just to be safe. Good Luck! Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 2, 2015 Share Posted December 2, 2015 Check for 12V at the motor on both sides, and check at the Resistor block. Could also be a dead fan switch If you have voltage on both sides of the motor and both sides of the resistor. 1 Link to comment Share on other sites More sharing options...
Turbone Posted December 3, 2015 Author Share Posted December 3, 2015 No V at motor at all, is the resistor pack the same as the EA's? Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 3, 2015 Share Posted December 3, 2015 No voltage is gonna be a blown fuse or dead blower relay. Fan switch grounds the circuit after it goes through fuse/relay > blower > resistor. At least that's how it is on the 2nd gen legacy models. Link to comment Share on other sites More sharing options...
Turbone Posted December 4, 2015 Author Share Posted December 4, 2015 Is the relay part of the A/C ones in the engine bay? Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 4, 2015 Share Posted December 4, 2015 No. The ones under the hood are just compressor and radiator fans. Blower relay is under the dash somewhere. Maybe top left corner on the firewall? Link to comment Share on other sites More sharing options...
