wheel bearing stuck on axle
After FINALLY getting my cv axle out of the front passenger hub to replace the bearings, the inner bearing came out with the axle! 'Tis stuck pretty good on there and I need some tips on how I can get it of without ruining a good axle. 87 FWD GL 3door
A smaller power tool with a cutoff disk.
The bearing is probably ruined now anyway. So destroying it to save the shaft makes sense.
I think if I had one that stuck, I'd try to find a way to clamp and protect the axle end in a vise. Hammer on the outer race. Or find a big bearing splitter and puller to do it the more conventional way. I have a medium sized set, which works for normally tight ones.
In had that happen once the bearing is still on the axle and funny enuff i still have the axle and bearing we were replacing the axle but ended up putting a spare hub with good bearings in it with the new axle I didn't trust the old hub seeing as how the bearing came out in one piece i figured the hub was wore out and i didn't want to even try to save the old bearing
