I am posing this as a feed back idea. I am going to lift my wagon, method is yet to be determined. I have a set of 31x10.5 tires, I know the limitations of the strut perch, body and axle angle. My idea is to remove the mounting socket from the strut and clean to its tube form then insert the cleaned tube into a longer socket re attache the adjuster to the new socket position for camber and weld solid to gain clearence for taller tires. Feed back is requested to ney or yea on the idea of increasing perch height on the strut.
