EJ25 Head Bolt lube - Oil vs leftover ARP lube
Will using the lube that comes with ARP bolts/studs cause stock head bolts to be overtightened? I know that ARP has different torque specs when their lube is used vs oiled threads. Just wondering if it would be a bad idea to use some of the ARP lube I have left over from some previous cast iron motor builds.
