ib759 Posted December 18, 2015 Share Posted December 18, 2015 (edited) First time owner of a Subaru. First time member of a forum. Joined because I'm having a problem with my low beam headlights not working on my 2000 legacy sedan. Hi beams work fine. Tested the bulbs, installed 1 new one, but I'm confused by the fact that when I check for current with a test light I have current at all three terminals on the bulb sockets with the switch set to hi beam and the middle and one outside terminal with the switch set to low beam. Shouldn't the middle terminal be ground? I'm also having problems with the left turn signal. most of the time I have to wiggle the lever to get them to flash and then they flash about twice as fast as the right side. All the bulb seem to be fine, at least all the four ways flash.Is it the turn, light and dimmer switch? I'm open for sugestions. Edited December 18, 2015 by ib759 Link to comment Share on other sites More sharing options...
Olnick Posted December 30, 2015 Share Posted December 30, 2015 Well, you chose the right car . . . and the right forum!!! Welcome. Suggest you post your headlight questions on the New Generation forum--you're more apt to get answers there. Link to comment Share on other sites More sharing options...
