gardorr Posted December 27, 2015 Share Posted December 27, 2015 (edited) I have a 1999 legacy 2.2 that is sluggish, lacks power and sputters until it reaches about 3300 RPM's, then it's like something kicks in and the cars runs great. If the car is allowed to cool off and you reset the ECU (Unplug the ECU or battery) the issue temperately goes away, but after running for approximately 20 - 30 minutes, the issue slowly returns. Any idea's? Edited December 27, 2015 by gardorr Link to comment Share on other sites More sharing options...
RED DEVIL Posted December 27, 2015 Share Posted December 27, 2015 Any codes? When was the tune up, fuel treatment? And only when cold 3300 is fine? Sounds like a bad head gasket and coolant pressure is making its way into the head. Link to comment Share on other sites More sharing options...
gardorr Posted December 27, 2015 Author Share Posted December 27, 2015 No codes and it has a fresh rebuild on it. Everything been replaced including the head gaskets. Link to comment Share on other sites More sharing options...
gardorr Posted December 27, 2015 Author Share Posted December 27, 2015 Once it starts acting up it doesn't stop until you reset the ECU. So even if I let it cool off and then started it back up the issue persists. Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 27, 2015 Share Posted December 27, 2015 Knock sensor. Link to comment Share on other sites More sharing options...
gardorr Posted December 28, 2015 Author Share Posted December 28, 2015 I already tried replacing the knock sensor, but it didn't change anything. Link to comment Share on other sites More sharing options...
