AK aaron Posted December 27, 2015 Share Posted December 27, 2015 ive changed the switch in the door and the relay. should i get all new wires? i dont know what else to do. thinking i just might try to find some doors with manual windows. or maybe just a manual regulator and track for the inside? and help/suggestions are greatly appreciated. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 27, 2015 Share Posted December 27, 2015 Txakura found a very interesting, non-conventional cause for the problem, Also, he found the Solution: ~► http://www.ultimatesubaru.org/forum/topic/92467-power-window-repair/ Kind Regards. Link to comment Share on other sites More sharing options...
maozebong Posted January 11, 2016 Share Posted January 11, 2016 Id check the wiring splice under the passenger carpet if you havent yet. door jamb wires are possible too, but harder to check Link to comment Share on other sites More sharing options...
Kbsubie Posted January 15, 2016 Share Posted January 15, 2016 Can you be more specific as to the location of the wires on the passenger side. We also are trying to track down faulty window wiring Thanks Link to comment Share on other sites More sharing options...
wagonist Posted January 15, 2016 Share Posted January 15, 2016 (edited) Have you cleaned the switches? The contacts get coated with crud after time. Main controller is under the carpet under front seat. Both the switches on the door and main switch need to work for window to operate Edited January 15, 2016 by wagonist Link to comment Share on other sites More sharing options...
wagonist Posted January 15, 2016 Share Posted January 15, 2016 Btw, do the motors in the doors work? Unplug them and connect the battery directly to check Link to comment Share on other sites More sharing options...
maozebong Posted January 16, 2016 Share Posted January 16, 2016 passenger front floorboards: all power and ground for windows splice off one (two actually, one power/one ground) 10 ga wire under the carpet. they are not sealed from the elements, just wrapped in tape... and soggy boots in the winter tend to soak it in salty water. Link to comment Share on other sites More sharing options...
