You're sure all the hash marks lined up, i.e. it's not a tooth off anywhere? Is it just moisture dripping from the tail pipe from sitting? Were there any such issues before the timing belt broke?
all timing hash marks line up, it's steady dripping and didn't have any issues before belt broke
Hm ok is it giving any codes? You might not have touched the air filter / intake stuff for the timing belt, but if you did, are you sure all the little hoses and such are all reconnected? Often one or more, especially the breather hoses going to the valve covers and sometimes the big hose going to the iacv likes to unhook secretly underneath and then lets air bypass the MAF which makes the vehicle unhappy.
I think all hoses are reconnected will double check them tomorrow  thanks
