MKPNG Posted December 28, 2015 Share Posted December 28, 2015 I have a 2000 Subaru Forester with 210,000 miles on it. When I start it, it idles fine. However, as soon as I put it into gear (either drive or reverse) the RPM drop down to 4-500RPM and the check engine light starts flashing. I have had a history of a misfire on my #2 cylinder. Does anyone have any suggestions as to what I might be looking at with these issues? Link to comment Share on other sites More sharing options...
jp98 Posted December 29, 2015 Share Posted December 29, 2015 Without the code everyone would be just guessing. You can get the code red for free at Auto Zone and Advance Auto and perhaps other parts stores. Then once the give you the code you can come back and post it. Link to comment Share on other sites More sharing options...
987687 Posted December 29, 2015 Share Posted December 29, 2015 Flashing CEL means you have a persistent misfire. What's the history of your misfire and what have you done to remedy it? You're missing a lot of the story that might help us figure out the issue. 1 Link to comment Share on other sites More sharing options...
matt167 Posted December 29, 2015 Share Posted December 29, 2015 when those issues come up. the basics of a tune up are what you do first. new spark plugs and new NGK plug wires 1 Link to comment Share on other sites More sharing options...
subarukris Posted March 24, 2022 Share Posted March 24, 2022 i have the same problem 2005 impreza turbo flashing cel runs rough at low rpm seems ok at higher rpm gona check plugs and cop's Link to comment Share on other sites More sharing options...
idosubaru Posted March 24, 2022 Share Posted March 24, 2022 1 hour ago, subarukris said: i have the same problem 2005 impreza turbo flashing cel runs rough at low rpm seems ok at higher rpm gona check plugs and cop's Flashing is multiple cylinder misfire. Install new Stock NGK plugs only. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 24, 2022 Share Posted March 24, 2022 running premium fuel right? Link to comment Share on other sites More sharing options...
