Flashing Check Engine Light
I have a 2000 Subaru Forester with 210,000 miles on it. When I start it, it idles fine. However, as soon as I put it into gear (either drive or reverse) the RPM drop down to 4-500RPM and the check engine light starts flashing. I have had a history of a misfire on my #2 cylinder. Does anyone have any suggestions as to what I might be looking at with these issues?
Without the code everyone would be just guessing.
You can get the code red for free at Auto Zone and Advance Auto and perhaps other parts stores.
Then once the give you the code you can come back and post it.
  • 6 years later...
1 hour ago, subarukris said:
i have the same problem 2005 impreza turbo flashing cel runs rough at low rpm seems ok at higher rpm gona check plugs and cop's
Flashing is multiple cylinder misfire.  Install new Stock NGK plugs only.
