mark384 Posted January 1, 2016 Share Posted January 1, 2016 92 Subaru legacy 2.2 getting fuel into oil how to tell if injector is stuck opened of if it's the o-ring which look good thanks for any help Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted January 1, 2016 Share Posted January 1, 2016 Another possibility might be the fuel pressure regulator but I don't think I've seen any posts of that as a failure mode on soobs at least not for leaking fuel into the oil. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted January 1, 2016 Share Posted January 1, 2016 Another possibility is a bad spray of the injector. Add a can of fuel injector cleaner to your gasoline. Get the good stuff that cost more then $8/can like Techron. The cheapie stuff doesn't help much. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 1, 2016 Share Posted January 1, 2016 How does the engine run? Does it idle rough? If the engine is misfiring you'll get fuel in the oil quick. How old are the spark plugs and wires? Quote Link to comment Share on other sites More sharing options...
