NA spider V's turbo spider inlet manifold
somewhere in here was a link to a craigslist? ad for the awesomely modified blue 79? BRAT ute running an EA82T with spider inlet. The blurb claied it had a non turbo inlet manifold and it flowed better than the turbo one. Find this hard to believe if it is the NA spider V's turbo spider! It may be a case of NA spider being used due to it flowing better than the non spider turbo inlet manifold ?
not breathing in ... there are two part numbers for the spider manifold and difference looks to be the NA or turbo !
the water log base sections are different only as far as I can see for the turbo coolant pipe off the thermostat lower casting. Cannot see how they would alter castings between the two modes myself
