gizmo432 Posted January 6, 2016 Share Posted January 6, 2016 I have a 2.2 turbo in my Funco Sandrail. I don't have a VIN and I need to figure out which motor it is. I need to replace the timing belt and water pump. Are they all the same on the 2.2L SOHC turbo? Is there a number on the block that might help? Anything to look for? Thanks Link to comment Share on other sites More sharing options...
johnceggleston Posted January 6, 2016 Share Posted January 6, 2016 as far as i knOW, THE ONLY TIME THEY MADE AN EJ22 TURBO in the USA was 90 - 94, and i don't think they made them all 5 years. if you bought a JDM engine then it could be any year. but as long as it is in fact an ej22 block and haeds, they are all the same. same belt size, same idlers, same water pump? but there could b a ''high endurance'' belt or something, i guess. Link to comment Share on other sites More sharing options...
gizmo432 Posted January 7, 2016 Author Share Posted January 7, 2016 How do I know that it is EJ22? I am just guessing because I think it is a non-interference motor because when the belt broke it did no damage...the car just died. I want to be able to look at the motor and see some identifying something that I can cross reference? Anyone know what I can do or a place online where there are pictures of this model and another model and another model side by side?? Link to comment Share on other sites More sharing options...
johnceggleston Posted January 7, 2016 Share Posted January 7, 2016 look on the block under the alternator. there should be a casting in the block. ej22 or ej18 or ej25. i take it you did not build your sand rail, you bought it already built. Link to comment Share on other sites More sharing options...
TOONGA Posted January 7, 2016 Share Posted January 7, 2016 At the front of the motor where the oil light sender is there will be a little box with the "EJXX" identification this picture shows an EJ20 motor id from this thread http://forums.nasioc.com/forums/showthread.php?t=1468169 hope that helps as well the engine number is on the back of the block good luck TOONGA Link to comment Share on other sites More sharing options...
gizmo432 Posted January 7, 2016 Author Share Posted January 7, 2016 I did not build my rail and I appreciate all the help. I will check this out when I get home. Thanks Link to comment Share on other sites More sharing options...
porcupine73 Posted January 7, 2016 Share Posted January 7, 2016 (edited) On 1/7/2016 at 12:05 AM, gizmo432 said: How do I know that it is EJ22? I am just guessing because I think it is a non-interference motor because when the belt broke it did no damage...the car just died.How do you know there's no damage if the new belt isn't on yet? (Maybe you mean it broke a previous time and was replaced and didn't do damage then, but hasn't yet broken this time?) For the water pump I think in the 90's there was a 'high velocity' water pump that I believe was for the turbos, that might have been the cast vs stamped impeller debate that came up from time to time back when. Edited January 7, 2016 by porcupine73 Link to comment Share on other sites More sharing options...
