I have a terrible hum/whine coming from the rear of my 91 Legacy(220K). I thought it was a wheel bearing, but when I pulled the wheels, calipers, and rotors there was no play or sound. I got in the back seat/trunk area to try to get a better idea of what it was, I couldn't definitively say it was from the left or right. When you take your foot off the gas, it does get an additional noise, what I would call a "gear" noise, which has me wondering about the diff. I recorded a short video...
How can I definitely rule out a wheel bearing or the diff without tearing into the hubs?
Bad wheel bearings can be hard to identify.
I had a noisy 'rumble' from the rear, gradually getting worse, but I couldn't figure out if it was left or right.
- I tried an infrared thermometer - no temperature difference between left and right.
- I tried jacking up the wheels and rocking the tires - couldn't feel anything. Tried that many times.
- I tried a stethoscope on the hubs while rocking the wheels - couldn't hear anything.
Then, eventually, when doing the rocking test, I heard a very faint 'click', couldn't feel it just heard it.
Had that wheel bearing changed, and all was quiet.
Having said that, your noise is more of a 'whine', which I would expect to hear from a noisy gear-set.
So it might be the diff.
Does the diff get warm after driving at high-speed?
That's a good question... I'll go take it for a quick drive a mile down the highway and see.
OK, yes, the diff is a bit warm. 2 mile round trip on the highway.
Also, it feels like there is resistance when you start off - like driving through snow, or with your parking brake on. You hit about 30mph and it "lets go" - meaning the resistance/drag goes away until you stop the car again. The sound becomes audible around 20mph.
Diff fluid was black, thick, and smelly, but no chunks of metal. There was a little bit of the normal "filings" on the magnetic plug, actually less than I've seen on some of the fluid change videos on YouTube. It might have also been a bit low - it's definitely leaking oil from somewhere, looks like maybe it's leaking past the axle shaft seals. I filled it up with fresh fluid and took it for a drive. No difference. I'll spray the diff off with engine cleaner to see if I can tell where it's leaking from.
I had my wife drive past me a few times so I could get a listen from the outside, I'd say it's coming from the driver's side. So I'm thinking it's the rear driver's side wheel bearing at this point.
  • Like 1
  • 3 weeks later...
