Ashwell Posted January 11, 2016 Share Posted January 11, 2016 Can't believe the attention you get driving around! Link to comment Share on other sites More sharing options...
LovemyGLWGN Posted January 11, 2016 Share Posted January 11, 2016 Yes! That is what I had planned for mine, before it just 'crapped out' on me. Height of lift? Link to comment Share on other sites More sharing options...
Ashwell Posted January 11, 2016 Author Share Posted January 11, 2016 2 inch lift with 1.5 crossmember spacers from ADF. Well worth the work and money! Way better than I expected it to be! Link to comment Share on other sites More sharing options...
Prwa101 Posted January 13, 2016 Share Posted January 13, 2016 That thing looks awesome man!!!! Glad it worked out for you! Patrick Anderson Design-fab Link to comment Share on other sites More sharing options...
14wrx Posted January 13, 2016 Share Posted January 13, 2016 What is your wheel/tire setup if you don't mind me asking? My GL is lifted but trying to find the right size tires to run! Link to comment Share on other sites More sharing options...
LoyaleWithCheese* Posted January 14, 2016 Share Posted January 14, 2016 looks really good. i'm wanting what looks like the same tire size. i dont want to have to cut anything so i'm assuming a 4inch lift cover that. i also intend on pulling a 1500lbs travel trailer with it after all said & done Link to comment Share on other sites More sharing options...
LoyaleWithCheese* Posted January 14, 2016 Share Posted January 14, 2016 what did you use to lift it? i'll prob get the SJR kit Link to comment Share on other sites More sharing options...
Ashwell Posted January 14, 2016 Author Share Posted January 14, 2016 I went with ADF 2inch with the 1.5 inch crossmember spacers. And im running 29 inch at3's. i had to cut quite a bit but it only rubs when i get close to full steering lock. or im bouncing pretty hard. still very driveable for everyday use. i have had no problems so far. but i do get more attention than if i ran down the street naked. 1 Link to comment Share on other sites More sharing options...
Rust Posted January 14, 2016 Share Posted January 14, 2016 Welcome to the lifted red wagon club, Where did you get the headlight eyebrows for yours? 1 Link to comment Share on other sites More sharing options...
Ashwell Posted January 14, 2016 Author Share Posted January 14, 2016 I just taped then off and put a light coat of off brand plasti dip on it look pretty good even up close. And the light shines right through no problem Link to comment Share on other sites More sharing options...
Ashwell Posted January 14, 2016 Author Share Posted January 14, 2016 I just taped the headlight off, then put a light coat of off brand plasty dip and the light shines right through looks good! Link to comment Share on other sites More sharing options...
