lost and found pcm module 85 brat
Okay Now that I have your attention , Do have wires either side of carb and one towards front right and one to air cleaner bottom.Still not seeing computer, And if it has not got one ? What would Stop the engine from starting and not pump gas------New fuel pump--That has been working fine.Still have spark at plugs --Will not start Even with starting fluid NOTHING Is there another sensor?What and where ?Thank you
Well, it sounds like a feedback carb. There should be connectors hanging under the steering column and an ECS light on the dash if it was a feedback vehicle. No, it won't run without the ECU. Nothing to turn the fuel pump on and to turn the shut off solenoid on.
