tennsubaru Posted January 13, 2016 Share Posted January 13, 2016 I've got a 91 loyale 5-speed and I've narrowed down my problems to being a disfunctional fuel pump. I'm wondering if I can put an aftermarket inline pump on or if I should just bite the bullet and shell out $140 on a new one? Money is tight but I do want it to last a good while and be reliable because the car's my daily driver. Thanks, Bobby Link to comment Share on other sites More sharing options...
wagonist Posted January 13, 2016 Share Posted January 13, 2016 Yes, but a couple of things to note. The factory pump has a right angle exit line, most aftermarket pumps go exit straight. Secondly, the factory pump has a filter screen on its inlet. A lot of other cars have this screen inside the tank, so you'll need to add a filter between the tank and the pump if you don't want it to die due to some debris Link to comment Share on other sites More sharing options...
Rust Posted January 13, 2016 Share Posted January 13, 2016 I usually go with a generic fuel pump, and put an in line filter before the pump. I have had good results using this brand in my subarus, take a look for yourself. http://www.pefp.com/make/Subaru.html Rock Auto lists the P17 generic fuel pump for under $30 Link to comment Share on other sites More sharing options...
tennsubaru Posted January 14, 2016 Author Share Posted January 14, 2016 Great! That's an awesome price, Link to comment Share on other sites More sharing options...
