beamsbox Posted January 21, 2016 Share Posted January 21, 2016 (edited) Not sure what this is... Or its purpose... Looks like i has a filter inside. Connecter to two vacuum lines? Maybe both are fresh air? Sits just to the rear drivers side of the intake manifold and engine. Off a 1986 GL Hatchback. Probably the same for Brats. Thanks! If you look close you can see that the two hoses connect to two different switches (?) on the intake manifold. Edited January 22, 2016 by beamsbox Quote Link to comment Share on other sites More sharing options...
robm Posted January 23, 2016 Share Posted January 23, 2016 Might be a filter, but mostly it is like an air receiver, kind of like a capacitor for vacuum. Gives a little volume, so it smooths out any pulses in the suction from the intake. Quote Link to comment Share on other sites More sharing options...
naru Posted January 23, 2016 Share Posted January 23, 2016 That is the secondary air filter. It filters air entering the carburetor air bleeds thru the duty solenoids. Both ports should breathe freely. Quote Link to comment Share on other sites More sharing options...
skishop69 Posted January 23, 2016 Share Posted January 23, 2016 spoob! Learn something new every day! My dd Brat doesn't have that! Doh! Quote Link to comment Share on other sites More sharing options...
beamsbox Posted January 23, 2016 Author Share Posted January 23, 2016 Thank you. Skishop, neither will my subie after I Weberize it. (I think...) haha. Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted January 23, 2016 Share Posted January 23, 2016 Thank you. Skishop, neither will my subie after I Weberize it. (I think...) haha. If your getting a weber delete all the emissions crap off. Only stuff i leave on mine is the egr and the cat so it passes deq but since your in washington you can delete those too. Quote Link to comment Share on other sites More sharing options...
comatosellama Posted January 25, 2016 Share Posted January 25, 2016 If your getting a weber delete all the emissions crap off. Only stuff i leave on mine is the egr and the cat so it passes deq but since your in washington you can delete those too. You should be able to disable the EGR between inspections by just taking off the vacuum line from it and capping the port on the egr and throwing a bolt with RTV and a hose clamp on the vac line. Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted January 25, 2016 Share Posted January 25, 2016 The rigs i have done it to have ran very well and have passed deq with a little tuning(they get in the mid 20's for mpg). My hatch has 2.2 in it now so i doubled my hp and put the weber on my dads hatch. My dads has 241 thousand miles on it and passed deq once the cat got heated up. I was kind of surprised since it has worn valve seals that makes it roll coal when you start it up cold. Quote Link to comment Share on other sites More sharing options...
