Rust Posted January 25, 2016 Share Posted January 25, 2016 Tried searching, did not find anything. Just wondering if this has ever been attempted, or is it impossible. Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted January 25, 2016 Share Posted January 25, 2016 It's been done before. I know Loyale 2.7 turbo put a front clip from a xt6 on one. I've seen others but it's a tight fit. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 25, 2016 Share Posted January 25, 2016 Yes and is a really Bad idea. Unless you want to upgrade Brakes, Suspension, etc... and make room for a Radiator; besides other many things. You can See photos and read further info, here: ~► www.ultimatesubaru.org/forum/topic/122165-ea82-to-er27-swap/ However, others succeeded with that idea; such like this EA82 coupe with six cylinder subaru engine swap in Russia, video here: ~► https://www.facebook.com/100004138294409/videos/576652559149349/ Kind Regards. Quote Link to comment Share on other sites More sharing options...
subnz Posted January 26, 2016 Share Posted January 26, 2016 Yes and is a really Bad idea. Unless you want to upgrade Brakes, Suspension, etc... and make room for a Radiator; besides other many things. You can See photos and read further info, here: ~► www.ultimatesubaru.org/forum/topic/122165-ea82-to-er27-swap/ However, others succeeded with that idea; such like this EA82 coupe with six cylinder subaru engine swap in Russia, video here: ~► https://www.facebook.com/100004138294409/videos/576652559149349/ Kind Regards. Totally agree why would you want to do this? Easier to buy a car with the H6 fitted that it was designed for. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted January 26, 2016 Share Posted January 26, 2016 I disagree. H6 swap cars are a blast. Peak power isn't as much as many turbo setups, but the torque curve is addictive. Turbos add a definite level of complexity to a car, and typically that reduces the reliability. "There's no replacement for displacement" is definitely true, and while I think that 7 or 8 litres is certainly overkill, but ~3 is perfect. The ER27 is probably more work than it's worth. It's almost as long as an EG33, has a 3rd motor mount to the lower radiator support, and doesn't have much more power than a decent EJ. I've seen a couple ER27 into EA81 swaps. ER27 ECUs are mounted in the trunk, so while the electrical functionality isn't actually more complicated, having several feet more wire to deal with can add it's own challenges. An EG33 is a fantastic engine. An EG-swapped GC impreza will out run a GD STi in a straight line, and an EA82 chassis is even lighter. No, it's not an easy swap, but it's doable. As with any swap that increases the power by 2-2.5 times, you will probably want to do some suspension and brake upgrades, but those aren't terribly difficult. You'll probably want an EJ AWD transmission, which requires a little work, but also completely doable. The EG33 is more than a little bit bigger than an EA82, so you'll have to move the radiator forward. That's easier on an EJ car, as you have a fairly large, plastic bumper that you can hide stuff behind, but again, doable. Probably would require a shorter and thicker radiator. An EZ30/36 would be the easiest swap, mechanically, but the most expensive. As it's not much bigger than an EJ. I bet it could be done with the stock EA82 radiator, in it's stock mounts, and pusher fans. '01-'04 EZ30s are extremely reliable (comparable to an EJ22e), and IIRC the wiring is simpler than almost any EJ turbo setup.... '05+ EZs have an immobilizer system. So in order to use one of those engines, you'll have to go standalone management, which will add significant cost. 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 26, 2016 Share Posted January 26, 2016 Yes, while the Subaru ER27 engine swap is a bad idea because it doesn't woth the effort, the Subaru EG / EZ engines swap is great, but might be very Expensive to be well done, because it needs the EJ transmission to be reliable... Some months ago, I shared this at the Legendary "Strange & Weird Subaru Stuff" Thread: My friend from Russia, Ruslan Halitov (Russell-555) shared this photos of an impressive Subaru Leone Coupe, with a Six cylinder engine Swap, that came out from a Subaru SVX; it accelerates abruptly Fast with manual transmission, I have a Video also... Thank you Ruslan! ... Kind Regards. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted January 26, 2016 Share Posted January 26, 2016 However, with enough time, money and skills, Almost anything could be done to a Car... ...Kind Regards. Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted February 8, 2016 Share Posted February 8, 2016 The EZ30 would be the best fit. As is clear from the pictures of the russian coupe the EG33 leaves no space for the radiator. Quote Link to comment Share on other sites More sharing options...
D3F0 Posted February 26, 2016 Share Posted February 26, 2016 Also I dont think it is possible to use the orginal postion when I measured everything up it was like 7 inches longer than my ea82. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 27, 2016 Share Posted February 27, 2016 You'll need to fabricate Motor Mounts... Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 27, 2016 Share Posted February 27, 2016 The EZ30 would be the best fit. As is clear from the pictures of the russian coupe the EG33 leaves no space for the radiator. Exactly! ↑ Look at the Photo above. Quote Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted February 27, 2016 Share Posted February 27, 2016 (edited) Nevermind I'm a idiot Edited February 27, 2016 by SubaruWagon87 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted February 27, 2016 Share Posted February 27, 2016 EG33's and EZ's have been installed into XT6's which are based on an EA82 XT. EA82's have less forward clearance, that's the only major issue right? Move radiator, remove/move A/C. very little side clearance too so do the valve cover gaskets and spark plugs before installing. Quote Link to comment Share on other sites More sharing options...
