warmblood58 Posted January 26, 2016 Share Posted January 26, 2016 (edited) I have a '94 Legacy EJ22 and need to disconnect ECU - anything I need to know about removing connectors other than being careful? Are there clips? My connectors are yellow, do they simply pull straight out or are there clips to compress, etc.? Thank you! Edited January 26, 2016 by warmblood58 Link to comment Share on other sites More sharing options...
warmblood58 Posted January 26, 2016 Author Share Posted January 26, 2016 Just want to ensure I do not break anything in disconnecting. Link to comment Share on other sites More sharing options...
987687 Posted January 26, 2016 Share Posted January 26, 2016 There's a little tab/button in the middle of each connection you push in, then you can remove the connector. 1 Link to comment Share on other sites More sharing options...
warmblood58 Posted January 26, 2016 Author Share Posted January 26, 2016 There's a little tab/button in the middle of each connection you push in, then you can remove the connector. Thank you! Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 27, 2016 Share Posted January 27, 2016 Not sure on the 94, but yellow connectors are usually for airbag components. Lots of different plugs and connectors out there. There is almost always a lock tab of some type that must be pressed before the connector will come apart. The 95 ECU has a small lock tab that holds a lever. Flip the lever open and the connector pulls away. Link to comment Share on other sites More sharing options...
