Flowmastered87GL Posted March 23, 2016 Share Posted March 23, 2016 Yes. It is the rotary rx, it seems a bit sacrilegious but I can't express just how poorly it was swapped. There's a reason I cut the entire front end off Took me a while to find them... but here are some REALLY old pictures of this car.... maybe early 2000's?? 1 Link to comment Share on other sites More sharing options...
rpholz Posted March 26, 2016 Author Share Posted March 26, 2016 Broke it. And the trans. Also, moving jobs, not sure on the dyno in the future Link to comment Share on other sites More sharing options...
D3F0 Posted March 27, 2016 Share Posted March 27, 2016 What do you mean you broke it and the trans? You blew the engine and stripped the transmission? Link to comment Share on other sites More sharing options...
rpholz Posted March 27, 2016 Author Share Posted March 27, 2016 So, put it back on the dyno, running good. 12psi netted like 150-160hp theeeeeeen it started to break up. Took some timing out, fattened it up still not running right, also running hotter, put it in vehicle sim, yep, getting hot runs like spoob, said codswallop it, it's broken. Turned anti lag on, got some great fireball video, cranked the boost to the moon, drove it around back and launched it so hard it all came apart, it still runs and you can still somewhat find gears but it's done. Which is OK, I got fed up when it started to break up. Not sure what's going back in it but it's done for now. MEH, WJM would be proud. 2 Link to comment Share on other sites More sharing options...
rpholz Posted March 28, 2016 Author Share Posted March 28, 2016 Link to comment Share on other sites More sharing options...
D3F0 Posted March 28, 2016 Share Posted March 28, 2016 Hard launching and Subaru shouldnt be said in the same sentence. Everything always breaks that way. Oh well thats too bad good luck with your future plans. Link to comment Share on other sites More sharing options...
rpholz Posted March 28, 2016 Author Share Posted March 28, 2016 Meh, what's the point if I can't launch the hell out of it. Trans was on its way out anyway #justain'tcare 1 Link to comment Share on other sites More sharing options...
rpholz Posted March 28, 2016 Author Share Posted March 28, 2016 (edited) Alright. Had a look through my storage unit. Here's the options and I really don't know what to do and am open to suggestions. This is what I have (1) turbo ea w/fresh heads, good (1) rx gearbox, good (1) xt6 trans, missing front diff (1) 97 ej22, needs rebuilt (1) set of dual port 22 heads (1) ej18 intake w/rails no harness (2) wrx DBC throttle body, complete (1) spare TWE header (1) oe excedy RS clutch, good Do I ej it? MOD a twe header to fit the single port and turbo it? Put the spare ea in and see what it does? Find a 25 bottom end and build another frankenmotor? Eh, I just don't know. Edited March 28, 2016 by rpholz Link to comment Share on other sites More sharing options...
D3F0 Posted March 29, 2016 Share Posted March 29, 2016 If i were you I would take the back of your extra RX trans and put that on the back of an EJ trans with either a 3.7 or 3.9 final drive to match your diff I recommend that so you have the locking center of the RX tranny still and use the newer Ej trans to bolt the EJ22 you already have. With this option there is no need to to buy an adapter plate. Then turbo everything and I am sure with that option it will all hold together for some launches assuming you are not doing it at redline. EA82 are not that much fun to mod you would have way more fun building a turbo 2.2 using the old legacy heads if you can find them or lower compression and boost that baby. Link to comment Share on other sites More sharing options...
rpholz Posted March 29, 2016 Author Share Posted March 29, 2016 completed launches will be 3-3500rpm with a clutch switch, not worried there. im not going through the effort of finding ej22 turbo heads, ive looked before and either didnt like the price or the rariety. the open center diff does me zero favors and locking it will never come in use as its a street car, not for gravel, now if i can get past the rally america novice license restrictions that may be a viable option. space of an ej swap is always a concern and if i do turbo the 22 it would get pistons and bearings at minimum Link to comment Share on other sites More sharing options...
Numbchux Posted March 29, 2016 Share Posted March 29, 2016 If i were you I would take the back of your extra RX trans and put that on the back of an EJ trans with either a 3.7 or 3.9 final drive to match your diff I recommend that so you have the locking center of the RX tranny still and use the newer Ej trans to bolt the EJ22 you already have. don't do it. A ton of work, for the worst center diff Subaru ever made. Stick with the LSD. 1 Link to comment Share on other sites More sharing options...
D3F0 Posted March 29, 2016 Share Posted March 29, 2016 Why do u say its so bad? don't do it. A ton of work, for the worst center diff Subaru ever made. Stick with the LSD. Link to comment Share on other sites More sharing options...
Numbchux Posted March 30, 2016 Share Posted March 30, 2016 Why do u say its so bad? When unlocked (which it must be on pavement), you have nothing to force power to the rear. I can't count how many times I spun up a front tire like a Civic coming out of a turn while Autocrossing. And even with the improved castor and camber with the 5-lug swap, rallycrossing and especially ice racing where very difficult. The front tires have to be allowed to spin a little different speed than the rear for the front tires to bite on turn-in. With it unlocked, the front would bite, but you can't hold any oversteer or accelerate out of the corner, as the power all goes through one front tire. With it locked, you could hold the slide, and power out of the corner, but it took a massive flick to overcome the initial understeer. I have seen a standard 4Kg (I think.....might be 6), phase 1, VLSD center diff dig holes with both oversized back tires, while the whole car was high-centered and the front tires were hanging in space (Austin's WaterWagon 2, hours after it earned the nickname). It seems the phase 2 center diffs are stronger than phase 1, even though they're still rated the same....might just be that they're newer. Also, Subaru offers a 20Kg phase 2 replacement for Group N racing that is drop-in, and phenomenal. Not to mention DCCD. And adding 4.11 and 4.44 to your axle ratio options. 1 Link to comment Share on other sites More sharing options...
rpholz Posted March 30, 2016 Author Share Posted March 30, 2016 ^THIS Link to comment Share on other sites More sharing options...
rpholz Posted March 30, 2016 Author Share Posted March 30, 2016 lol 1 Link to comment Share on other sites More sharing options...
D3F0 Posted March 31, 2016 Share Posted March 31, 2016 Alright fine Ill use my legacy 4.11 5 speed instead lol thanks for the advice.Do you guys usually just swap the ring gear at the back to 4.11 to mach the tranny. Is that possible with that awesome rear LSD? Or do i have to do a bunch of crap and locate another diff. Currently I have an SVX/legacy hybrid built 4.11 and i doubt the RX axles would slide right into the SVX LSD prob different splines and length. ALSO LOVE THAT VIDEO I love it all haha Link to comment Share on other sites More sharing options...
rpholz Posted March 31, 2016 Author Share Posted March 31, 2016 ive not done ea-ej diff changes but on later stuff i just swap the center chunk, ei the pinion never comes out and i just swap the ring onto whatever diff i want Link to comment Share on other sites More sharing options...
D3F0 Posted April 1, 2016 Share Posted April 1, 2016 Yea i just have to take a look I bet it all bolts up and I just have to keep all the shims on to keep the back lash the exact same as before. Link to comment Share on other sites More sharing options...
rpholz Posted April 3, 2016 Author Share Posted April 3, 2016 took the turbo block, retorqued the heads. got a bit too lazy to take it off the back of the truck lol. it's in, running. dyno it tomorrow. running a fair bit richer currently. and for those wondering if the clutch will hold..... yea i think it will Link to comment Share on other sites More sharing options...
rpholz Posted April 3, 2016 Author Share Posted April 3, 2016 Won't do a clean pull, suspecting bad coil but can't find one local Link to comment Share on other sites More sharing options...
rpholz Posted April 3, 2016 Author Share Posted April 3, 2016 alright, codswallop it. im done. this car can sit for a while. Link to comment Share on other sites More sharing options...
rpholz Posted February 5, 2017 Author Share Posted February 5, 2017 ALMOST A YEAR LATER. Let's see: New job Bought a house Built a friends FC Turbo II and dismantled the rx. As it sits it has no harness, the core support is cut out, and the engine is on a stand. However ill be returning work. So far larger radiator, different intercooler, bigger VF52 turbo and a complete rewirering of the car(except my sweet engine harness) Stay tuned, don't stay tuned. Eh Link to comment Share on other sites More sharing options...
carfreak85 Posted February 7, 2017 Share Posted February 7, 2017 What are your plans for that TWE header? Link to comment Share on other sites More sharing options...
rpholz Posted February 8, 2017 Author Share Posted February 8, 2017 Hoard all of them Link to comment Share on other sites More sharing options...
